Results 1 to 5 of 5
  1. #1
    Default Yanmar 1gm10 steam in exhaust
    I have a new yanmar 1gm10 which is sea water cooled. The engine was run in last season and has about 60 hours on it. This season I have noticed quite a lot of steam coming out the exhaust when the engine is under high load. It doesn't look like the flow of water is restricted because I also see water coming out of the exhaust. The water is pretty hot. Apart from this the engine runs fine and starts perfectly first time. Is this steam normal? I didn't notice it last season but was not running the engine at full load.
    Thanks Marek.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: Yanmar 1gm10 steam in exhaust
    I believe it would be watervapour and not " steam "
  3. #3
    Quote Originally Posted by racerone View Post
    Yes I agree. I should have said water vapour. Anyway, the thing I want to establish: is this normal?
    Obviously its difficult to judge without seeing it. However I can say water vapour is not excessive, but it is certainly noticeable.
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    This is normal.---------And you will see more of that on a cool day.----------Not sure of where you are but on a sub zero day in the winter you will see lots of water vapour coming out of tailpipes in traffic jams.-------Not to be seen on a hot summer day !
  5. #5
    thanks for the advice! I'm in the UK it was about 60F yesterday probably cooler near the water surface.
Similar Threads
  1. Yanmar 1gm10 leaking oil from exhaust port stud bolt
    By adambowenfsmailnet in forum Yanmar
    Last Post: 01-27-2010, 07:06 PM
  2. Replies: 4
    Last Post: 05-10-2008, 09:50 PM
  3. Yanmar 1gm10
    By divakate212 in forum Yanmar
    Last Post: 11-06-2007, 07:44 AM
  4. 1gm10 yanmar
    By patrickholland in forum Yanmar
    Last Post: 09-09-2006, 07:43 PM
  5. Yanmar 1GM10
    By Dougie Muir in forum Yanmar
    Last Post: 05-01-2006, 12:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
