1 cylinder is not getting much fuel. I have swapped carbs and the issue follows the carb. Went through the carbs once but issue persists.
Will go through that carb again.
which passage is the idle circuit / jet?
Also, These carbs cross feed the cylinders, correct? IE, starboard top cylinder is fed by port top carb?
Thanks anyone for clarifying!
