Click for Detroit Diesel manuals!
Results 1 to 4 of 4
Thread: 8v71
  1. #1
    Default 8v71
    Im currently running a 8v71 in my boat that was revently aqquired.
    What is a good operating temp for this engine and what is to hot for it
  2. #2
    Join Date
    May 2015
    Default Re: 8v71
    The book I have says 160-185. My DDs run about 175 at 1800rpm.
  3. #3
    Default Re: 8v71
    On DD 671TIB's I run 160-170. I have a guess at what is too hot but there are folks here WAY more qualified then me to answer that.
  4. #4
    Join Date
    Nov 2009
    temecula, ca., usa
    Default Re: 8v71
    The above suggestions are ok. 180 f. Thermostats are common for these engines but 160f and 170f as well as 190f stats are available too.
    What you need to understand is that the temperature stamped on the stat is the temperature that the stat BEGINS to open. Then, as fuel is added to compensate for load the stat will be FULLY open at temperatures ranging from 185 for a 160f stat up to 197f for a properly operating 180f stat.
    So, in a nutshell, "normal" can be from 160 to about 200f. "depending".
    These engines should have an overtemp warning system that will alarm at 210 to 215f for safe operation.
Similar Threads
  1. 8V71 water in the oil
    By ssn575 in forum Detroit Diesel
    Last Post: 09-07-2014, 02:37 PM
  2. 8v71 itt
    By sealady in forum Detroit Diesel
    Last Post: 08-20-2011, 10:51 AM
  3. 8V71 TI marine overheating
    By bigfish in forum Detroit Diesel
    Last Post: 06-03-2008, 04:53 PM
  4. 8v71 needs more power
    By gyoder1 in forum Detroit Diesel
    Last Post: 11-02-2007, 01:18 AM
  5. Themostat on 8V71
    By 67roamer in forum Detroit Diesel
    Last Post: 09-20-2007, 08:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
