Results 1 to 8 of 8
  1. #1
    Default overheating problems in my larson 2007
    Need help
    If I cleaned the manifolds, replacing water pump and impeller (brand new), looking that I have pressure in the houses and !! keeps overheating my vortec 4.3 engine 2007…..what can I do ?
    Do I need to look for cracks? My oil is clean…. No mix
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,926
    Default Re: overheating problems in my larson 2007
    step 1 compression check,Was thermostat checked in pot of hot water,openning at correct temp. Is engine fresh water cooled?salt water?
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,469
    Ayuh,.... Mercruiser,..?? Volvo,..?? Something else,..??
  4. #4
    Compression is check and ok in 6 cil. thermostat brand new and inspected, the engine is fresh water cooled.
    I’m frustrated
  5. #5
    it is a vortec , mercruiser....I am really sad.
    If for some reason, inside the the engine exist a clog … should I need to take it out ?
  6. #6
    I mean, the engine
  7. #7
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,158
    one thread for one problem is standard practice....
  8. #8
    I already clean the manifolds with water pressure and acetone , do you think the problem still there ?. the clog could be there ?
Similar Threads
  1. larson se180 problems?
    By briffdogg in forum Mercruiser Sterndrive Forum
    Last Post: 08-08-2014, 04:53 AM
  2. larson se180 problems?
    By briffdogg in forum Mercury Mariner Outboard Forum
    Last Post: 08-04-2014, 07:54 PM
  3. Overheating 2007 mercruiser 5.7 mag mpi
    By driver_to in forum Mercruiser Sterndrive Forum
    Last Post: 07-06-2014, 03:31 PM
  4. optimax 150 hp year 2007 overheating problem
    By anglers in forum Mercury Mariner Outboard Forum
    Last Post: 01-03-2011, 06:04 PM
  5. 2007 4.3 L mercruiser overheating
    By Jeffrey 9898 in forum Mercruiser Sterndrive Forum
    Last Post: 07-09-2010, 12:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
