I have a 40HP model E40TELCR with what appears to be a neutral safety switch in the base of the steering handle bracket. At the bottom of the shift lever is a hole which contained the parts necessary to depress that switch when shifted into neutral. One or more of those parts popped off and went to the lake bottom. I am left with one round plastic disk that appears that it would push in the switch, a spring, but nothing to attach to the disk from the other side of the hole in the shift lever. I am unable to find a parts diagram that matches my motor on any of the sites. The attached photos explain the situation much better than the words. Any thoughts?
