MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Default Mariner 100HP 4 Cylinder 1988, seek advice on alignment shift shaft cam currently would not shift
    Hi Guys,
    Mariner 100HP 4 Cylinder 1988 -93 (exact year unknown)
    Problem is after changing shift shaft seal (due to excessive amount of water/exhaust oil in gear box, changed water pump gasket, driveshaft seals, shift shaft seal), it wouldn't shift and leave me only forward gear. The reason might be when I pull open the shift shaft bush to replace the seal, the shift shaft pop out and disengaged with shift shaft cam. It's said need to be tear apart all the gear box and do the alignment and assemble again.
    Before I do it, I'd like to seek advice from you all who has experience in that. How I can dismantle drive shaft? propeller shaft, anything need to be very careful at? I'm trying to get the tools to pull the propeller shaft bearing carrier now . Kind of heard some people said need a proper torque to dismantle pinion gear.
    Cheers
    Howard
  2. #2
    Default Re: Mariner 100HP 4 Cylinder 1988, seek advice on alignment shift shaft cam currently would not shif
    That sounds like the proper workshop manual is the right advice..
Similar Threads
  1. Shift Shaft/Bushing leaking under pressure-Need Advice
    By enginesilo in forum Mercruiser Sterndrive Forum
    Last Post: 03-16-2015, 08:04 PM
  2. 98 115 2 stroke 4 Cylinder shift shaft alignment shifting problem
    By thstek in forum Mercury Mariner Outboard Forum
    Last Post: 02-03-2015, 09:13 AM
  3. 1988-1992 Mariner 100HP engine, need advice
    By NewBoater420 in forum Mercury Mariner Outboard Forum
    Last Post: 06-08-2012, 06:30 PM
  4. 1988 evinrude 48 spl shift shaft
    By fastfirebird in forum Johnson Evinrude Outboard Archive
    Last Post: 08-20-2009, 01:49 PM
  5. Connecting shift shaft to the shift lever in a 1994 60 hp evinrude
    By brucea952 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2004, 02:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
