Results 1 to 1 of 1
  1. #1
    Default Borg Warner/Velvet Drive 72 - Question about pressure sender port
    Where exactly am I supposed to connect the pressure sender? On the diagram in the service manual, there are three ports, and I have attached the mentioned diagram here. One port for the oil to the cooler outlet, one for the mainline pressure tap and one for reverse clutch pressure tap. So I have attached the hose to oil to the cooler outlet, I have attached mechanical pressure gauge to the reverse clutch pressure tap, and I have attached the electrical pressure sender to the mainline pressure tap. Mechanically, everything runs perfect. When in reverse I do read the pressure on mechanical gauge, but in forward there is no pressure on electrical sender (no reading at the gauge). Sender, gauge and the wiring are OK (checked twice). Am I reading this diagram wrong, should I connect the sender to the cooler outlet? Where am I mistaking?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Similar Threads
  1. Borg Warner velvet drive
    By Steve hills in forum Marine Transmissions and Reverse Gears
    Last Post: 05-20-2013, 09:19 PM
  2. Borg Warner Velvet Drive 1.52:1 Price
    By Debunker in forum Marine Transmissions and Reverse Gears
    Last Post: 04-21-2013, 11:54 PM
  3. Borg Warner Velvet Drive Transmission
    By laro6688 in forum Marine Transmissions and Reverse Gears
    Last Post: 12-25-2011, 03:43 PM
  4. Borg Warner Velvet Drive Lay Up
    By coaster in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-10-2009, 06:32 PM
  5. Borg Warner Velvet drive vdrive w440 question
    By Rick Statham in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 05-07-2008, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
