3H8040001M | FUEL PUMP, F25/30A/B F9.9/15/18 | $63.48 |
Ok, the model is MFS15B2. That's the one with ABS enrichment, so no choke required.
3H8040001M FUEL PUMP, F25/30A/B F9.9/15/18 $63.48
The MFS20C uses the same fuel pump.
You could have an air leak, sucking air on the vacuum side of the pump (due to a bad o-ring on the primer hose, etc.) or insufficient tank venting, causing excessive vacuum when at speed, or an underperforming fuel pump, or any of several other issues, including a CD that is failing hot.
