Rjcamel2355
I was given a 200HP mercury today. Not sure of the year. I'll get the serial number tomorrow. Ran a compression on it and all cylinders seem to be around 120psi.
Dirt dobbers have had a party inside this cowling. Before I ever think of running it I'd like to clean it up.
What's the best way to clean the carbs? Soak them in something or just tear them down and clean them out with carb cleaner?
The oil tank and the advance box is still attached to this motor. I've been told to jerk them both off and mix my oil and gas. Which is fine.
Also it has the external trim (it's all bolted to the motor and not inside the boat if that gives an idea on the year or anything.
Prop size? Has a 23p on it currently.
I had a 150 drop a cylinder on me over the weekend and I'd really like to do everything I can to keep this one together. At least for the season.
Hints tips tricks lemme have them. Please and thank you.
