Click forPleasurecraft Marine parts and manuals!
Results 1 to 9 of 9
  1. #1
    Default PCM 454 7.4L Stalling after gets warm and won't start back till cool
    I have a 1990 Supra Saltare with a 454 7.4L. When I run the boat either in the drive way or on the lake after about 20-30 mins it will just stall out like u turned the key, and will not start back until it has cooled of 20 mins or so. I have replaced alternator, rebuilt carb, ballast resistor, coil, and ruled out a fuel problem after that. I don't know I am stumped. Any ideas or help would be great!!
  2. #2
    Default Re: PCM 454 7.4L Stalling after gets warm and won't start back till cool
    Has spark even after shut down and plenty of fuel flow from carb. Is there some kind of sensor or something that could be bad and heat up to cause shutdown?
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,842
    Why do you have a ballast?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    One has been installed on the boat since I have had it, is it not needed?
  5. #5
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,842
    Depends on what ignition system you have.
    Chris
    Jersey Shore.
  6. #6
    I know I have the flamethrower coil, as far as ignition I am not sure I will have to check. I think it may be a Mallory ??
  7. #7
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,184
    Quote Originally Posted by Austinalaaa View Post
    I have a 1990 Supra Saltare with a 454 7.4L..... and ruled out a fuel problem.....
    how did you do that?
  8. #8
    It still has pressure at the pump and is getting good fuel Threw the carb after it stalls.
  9. #9
    And yes the ignition is a Mallory by the way.
Similar Threads
  1. 1994 Mercury 25hp missing on top cylinder till warm up.
    By Ssimmons in forum Mercury Mariner Outboard Forum
    Last Post: 05-09-2016, 09:06 PM
  2. Won't run when warm, needs to cool down
    By mooselake in forum Yamaha Outboard Forum
    Last Post: 07-08-2013, 09:16 PM
  3. Replies: 1
    Last Post: 04-07-2013, 03:10 PM
  4. 165 runs good till warm then locks and starts back up
    By firemanlowden in forum Mercruiser Sterndrive Archive
    Last Post: 07-28-2008, 08:54 PM
  5. 2002 Johnson 175 hp V6 stalling on warm start
    By jwbmarine in forum Johnson Evinrude Outboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
