Results 1 to 2 of 2
  1. #1
    Default QSB 5.9 Diesel View issue
    I am running a single QSB 5.9 with Diesel View (starboard configuration) and my Diesel View screen has stopped working, also once the engine starts it will not shut off when my run/start/stop switch is placed in the stop position. I have replaced the screen harness (found some broken wires), the screen, and the start switch. When I installed the start switch everything went back to normal and I did several starts and stops, the screen worked and the engine shut off by the switch, then the next morning it was right back to non-working screen and engine will not shut off unless I kill the breaker for the ECM or Cummins converter. Anyone have any idea where to look for this issue?
  2. #2
    Join Date
    May 2015
    Location
    Oregon
    Posts
    81
    Default Re: QSB 5.9 Diesel View issue
    With an intermittent problem, you're going to have to go thru every related wire and check the components on control boards. Often circuit board don't get properly soldered. It could be a corroded plug. There is no easy answer unless you just want to throw parts at it.
Similar Threads
  1. Murphy Power View 101
    By cmack in forum Crusader Marine Engine Forum
    Last Post: 05-04-2011, 02:30 PM
  2. Murphy Power View 101
    By cmack in forum Volvo Penta Gas Engine Forum
    Last Post: 01-05-2011, 06:45 PM
  3. Fuel pump exploded view
    By p vella in forum Johnson Evinrude Outboard Archive
    Last Post: 06-16-2008, 08:44 AM
  4. Where to get an exploded view
    By Weber in forum Johnson Evinrude Outboard Archive
    Last Post: 06-15-2008, 01:27 PM
  5. Need exploded view
    By dlh9350 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-14-2008, 01:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
