Click for Volvo Penta manuals!
Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2006
    Location
    , ON, Canada
    Posts
    5
    Question TAMD71B - Exhaust leak between the Turbo and Exhaust Elbow at the V-Clamp
    I have a TAMD71B and after cleaning the Exhaust elbow I replaced both the flange that connects to the turbo as well as the V-clamp that holds the Exhaust elbow to the flange. The mating surfaces are clean however I have an exhaust leak at the connection between the Exhaust Elbow and the Flange. The parts breakdown diagram does not show a gasket between the flange and the exhaust elbow. I've tried a number of things including Permatex Ultra Cooper High Heat Gasket Maker as well as also trying Rescue Tape around the connection before the v-clamp is installed. These are OK temporary solutions however they appear to fail over time. Can anyone recommend a permanent solution to my issue?
    Thanks,
    Mike
  2. #2
    Join Date
    Nov 2008
    Location
    Mobile, Alabama, USA
    Posts
    60
    Default Re: TAMD71B - Exhaust leak between the Turbo and Exhaust Elbow at the V-Clamp
    Don't know about your 71, I have two 41 series. My older one has no gasket and didn't leak when we took it apart and put it together. But our older AD41b leaked until we found there was a very small paper gasket that was in the diagram I found on volvopentastore.com. After putting that gasket in and coating it with Permatex Ultra Copper it doesn't leak now. Good luck.
  3. #3
    Join Date
    Nov 2008
    Location
    Posts
    60
  4. #4
    When you are mating the flange to your elbow is your hoses still connected to the elbow? I found that leaving The hoses attached puts strain on the elbow and does not let it tighten flatly to the flange if you remove the hose And just put the elbow on with the V clamp and tap it as you're tightening it you should get a nice even fit
  5. #5
    Had the same problem, because of some rusty flange no airtight seal possible, even after cleaning.
    Solution for me, some gun gum sealant on the flange and all is ok now
  6. #6
    I filed my mating surfaces nice and flat then with a new clamp and some never seize i was good to go
  7. #7
    Join Date
    Jun 2008
    Location
    Posts
    631
    Some Yanmars use a similar setup. Why they all can't just have a bolt on flange like other engines I do not know but I do know that exhaust leaks from those 'V-clamps' are always a possibility and they often need tightening again after a couple of runs.
Similar Threads
  1. Water Leak at Exhaust Elbow
    By 1coolbanana in forum Mercruiser Sterndrive Forum
    Last Post: 05-03-2015, 05:05 AM
  2. exhaust elbow
    By emuman in forum Volvo Penta Gas Engine Forum
    Last Post: 03-27-2010, 06:41 PM
  3. Exhaust Elbow Leak 60 MPI
    By mcaston in forum Crusader Marine Archive
    Last Post: 07-15-2009, 08:01 PM
  4. 19831995 Chrysler 440 exhaust manifold exhaust elbow
    By cassifree in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 05-07-2006, 07:04 PM
  5. Need exhaust elbow
    By Candy Hendrix in forum Archive 2002-2006
    Last Post: 10-30-2001, 09:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
