Hi everyone,
Here's my problem...I have '93 115 Johnson (J115MLETS). Put boat in water, started great, as usual. Rode down lake and turned key off and motor kept running. When I got boat home, found it had a faulty place in kill wire running from fuse boot to power pack. I pushed wire into boot and taped it up. The motor turned off with key. Took boat back to lake today and it started great and idles smooth. However, at WOT, my RPMs stay at 3500 and boat will not plane off. The carb is getting fuel. I pumped primer bulb while running and it did nothing to motor. I shot starting fluid into each cylinder and each one dies a little. So fuel is getting there. The plugs get wet with fuel during the WOT as well. On the trip home, there oil is dripping on my motor support from the fuel mixture that did not burn. Could the kill switch wire still be the culprit? Is there something I missed and need to reset?
