Ok guys I have a 1987 Mercury 60 hp that over heats at high speed. Like over 4000 rpm's. It will not overheat at lower speeds. This problem has been gong for a couple years. This is what I have done so far. I have had 3 new impellers installed and that has not fixed the problem. I took the back cover off the rear of the block. That exposed the water jacket. I did find a chunk of impeller in there, and thought that might have fixed the problem. No luck. I have been told that I should pull the head to see if there are any other pieces lodged in there. Your thought's are greatly appreciated.
Any suggestions??
Steve
Any suggestions??
Steve
