Results 1 to 5 of 5
  1. #1
    Join Date
    May 2016
    Location
    Amarillo,TX
    Posts
    3
    Default O-ring question on 1965 9HP VWB19077A Sea King
    Had my Sea King lower unit laying on it's side while removing the cup that houses the impeller. While jostling the unit, a very thin broken o-ring feel on the floor. Don't know if it came from on top of the impeller case or underneath the stainless plate under the impeller. OR did it come from one of my other projects and just fall off the bench? Even though it looks to be about the diameter of the drive shaft a good look didn't help me find a place this skinny little o-ring may have been or would do any good. Anyone familiar with the VWB series know the answer or maybe have an exploded parts view they may share by PM? Thanks!
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,647
    Default Re: O-ring question on 1965 9HP VWB19077A Sea King
    That is a chrysler built motor 1965 9.2hp I couldnt find any diagrams below 1974 is there a groove in the driveshaft just below the upper splines?
  3. #3
    Join Date
    May 2016
    Location
    Amarillo,TX
    Posts
    3
    Yes, about 1.5" below the top of the splines there is a groove around the shaft. The splines continue for about another .25" below the groove.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,647
    It probably keeps water out of the splines in the crank. Lightly grease the splines and put a new o-ring on when you install the lower unit.
  5. #5
    Join Date
    May 2016
    Location
    Amarillo,TX
    Posts
    3
    Thanks very much. I'll bet I can find an o-ring that size somewhere. I never thought to look that far up the shaft! Tunnel vision at it's best.
Similar Threads
  1. 18 hp 1965 evinrude Cam Ring
    By riversdavid in forum Johnson Evinrude Outboard Forum
    Last Post: 10-24-2014, 09:28 PM
  2. 1965 CD-22M 6HP Johnson question
    By patrick1955 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-09-2014, 10:09 AM
  3. 1965 Evinrude 6hp Shift Rod O-Ring
    By capnlazy in forum Johnson Evinrude Outboard Forum
    Last Post: 12-09-2011, 10:28 AM
  4. Gimbal ring to Bell hose question
    By txgalzdah in forum Mercruiser Sterndrive Forum
    Last Post: 11-10-2009, 12:45 PM
  5. 95 1965 Evinrude Question
    By jim rieschl in forum Johnson Evinrude Outboard Archive
    Last Post: 05-18-2004, 01:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
