Managed to flush the entire system without getting any AF in the bilge. Disconnected the water pump bypass at the filler neck, attached the suck-o-matic tank to the end of the hose and was able to pull five quarts. This effectively drained the top side hoses. Disconnected the system at the T-stat housing, removed the T-stat and collar hose. Using PVC tube and rubber couplings (with provided hose clamps) from Home Depot, directed fresh water directly to the HX while draining coolant from the T-stat housing in to five-gallon buckets. When the drained water was clear, inserted a new T-stat and reconnected the system. Sucked out another five quarts of water and added new AF. I'll check in the fall if more AF is needed to survive the Florida winter.
