Results 1 to 3 of 3
  1. #1
    Default Maximum Timing value 1983 150 hp
    Engine 150 hp year 1983. When timing the motor @ 4,300 to 4,600 it state to take the readings of both the number 1 & 2 cylinders and adjust the highest value cylinder to the maximum timing value listed on the motor. I can not find this info anywhere on the motor. Does anyone know what this maximum timing value might be for this engine?
    Join Date
    Apr 2010
    Posts
    4,252
    Default Re: Maximum Timing value 1983 150 hp
    If it's not on the air box cover it would be in the factory service manual.
  3. #3
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,214
    Suggest you post this question on the Johnson/Evinrude forum on this site. Go to top left of this page, click on "Forum Home" and click on Johnson/Evinrude.
    CHawk 25 DLX
Similar Threads
  1. 1983 mercury 80hp timing and idle questions
    By dchi2582 in forum Mercury Mariner Outboard Forum
    Last Post: 08-20-2015, 07:19 AM
  2. 8HP 2-stroke Mercury.......maximum timing adjustment -- ???
    By whitegreg56 in forum Mercury Mariner Outboard Forum
    Last Post: 04-02-2013, 10:38 PM
  3. 1983 v4 115hp crossflow Timing Problem
    By mo3444 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-28-2012, 01:15 AM
  4. 1983 45 HP help on timing
    By a_staples in forum Chrysler Force Outboard Archive
    Last Post: 07-13-2007, 02:26 AM
  5. JOHNSON 70HP 1983 TIMING PROBLEM
    By ROD KRUSE in forum Outboard motors archive 2000-2004
    Last Post: 05-13-2002, 10:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
