Results 1 to 4 of 4
  1. #1
    Default Missing second expected carburetor on my Newly-Acquired 1959 135 hp Interceptor
    I have a question for anybody with a Dearborn Marine Ford 135 hp, Interceptor engine. I just really had a good look at my newly-acquired 1959, 19' Lyman Runabout, and it my V-8 Interceptor only has one (the forward one) of its two Carter YH Carburetors. There is a plate bolted to the rear side of the intake manifold (where I expected the other carb), and a plate screwed top of the block (where I expected the second-carb throat to be).
    Is this the way it came out of the factory, or did the previous owner (deceased, so I can't ask him-), or his mechanic remove the second carb (for balancing problems)?
    I assume the previous owner ran it for a while (to what performance?) with this setup.
    Before I buy another Carter YH, or (more modern carbs?), maybe I can get some educated comments? -Alan Briggs
    __._,_.___
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,086
    Default Re: Missing second expected carburetor on my Newly-Acquired 1959 135 hp Interceptor
    according to this article, third paragraph:
    http://www.fiberglassics.com/library...borna59003.jpg
    it looks like the factory provided two - why one was removed is hard to say...
    you may wanna try oldmarineengine.com, too - many over there that deal with older stuff...
  3. #3
    Thank you, Makomark. I appreciate the information.
    -Alan
  4. #4
    Join Date
    Jul 2007
    Location
    McCall, Idaho, USA
    Posts
    29
    I have seen photos of the 135 hp Interceptor with one carb. I believe that was the way it was done.
Similar Threads
  1. Need help with newly acquired boat
    By boatnewb in forum Volvo Penta Gas Archive
    Last Post: 08-06-2009, 11:12 PM
  2. 1959 Interceptor 272 torque specs and water pump questions
    By eriktork in forum Ford Interceptor Marine Engine Forum
    Last Post: 05-27-2009, 09:59 PM
  3. Newly acquired 360 oil filter housing question
    By cassandroid in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 01-26-2009, 08:43 PM
  4. Recently acquired Mariner Yamaha Outboard Year
    By Ian McEachran in forum Mercury Mariner Outboard Archive
    Last Post: 07-13-2006, 05:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
