I just completed my rebuild. It took me about 45 mins. and $45 worth of parts. Assuming that the removal and install are a guaranteed labor concern, even for a new pump, I disassembled mine, cleaned in solvent tank, brushed out, and reassembled in about 45 minutes. I could have beat this had I been able to find my good needle nose pliers. I figure a novice (I am performance oriented, with a wall of trophies to back it up, as well as a diesel mechanic and a welder, truck driver, and air conditioning spe******t) should be able to complete this project from start to finish in 1 hour, figuring removal and install of fuel pump from engine, with basic hand tools, matco screw drivers, punches, ball peen hammer, needle nose, brush and brake cleaner to go, gasket or razor blade scarper, and the parts kit from ebay for 428 CJ ford fuel pump rebuild. I bought mine direct since it is cheaper, but ebay has the exact same one priced fair. I now have a $100 fuel pump, rebuilt for $44 and less than one hour, and I know that it is right, unlike the BRAND NEW stihl chain saw that had the fuel/vacuum lines reversed and would lean out at rpm and the store "mechanic" says it is fine. New stuff isn't always right. I have plenty of failed new parts out of the box. If I can reman myself, the quality is always top notch. If I buy new the quality often suffers, Wasting valuable early morning hours of trolling on the lake. I encourage a pump rebuild so long as you have access to a good core of an old style carter pump. The new ones are harder to obtain parts for, and have a different style filter. I wouldn't recommend paying $100 for a reman pump, that is probably imported from china, to save 30 minutes. New isnotalways perfect and if you do it yourself it isa one beer project, 2 at most, and the end resultwill be you have a nice fuel pump and a thicker pocket book. Use the proceeds to buy rapalas and troll for fish!!
