Just bought a 1983 Bayliner Capri with the motor mentioned. I've noticed when starting the motor, I would need to have the throttle at near max for the motor to fire up. Once it fires, it will run at 1000-1200 for a few seconds and start to rise of course. I'd then back-peddle back to keep the RPMs down until it would eventually hold at idle and run just fine. The motor rarely starts in the idle position and if does, or if I pull the throttle back too quickly the motor will die.
My question is what is the cause of this? Is this a fuel issue? The battery is holding a full charge during this.
As someone who is learning, what steps should I take/do to help improve or take care of this motor.
Thanks for any help.
