I have a 1996 225 evenrude on a 20' Stratos FS. The boat getts on plane very quick and easy but at top end I only get 48mph gps and 4800rms and if I trim more the prop blows out and max rpms is only 5100. Motor starts and runs fine but I feel that I should get way better top end. Even when prop blows out it sould over rev to about 6100rpms. I have changed pulugs from Chamion to Recumended NGK. The Champions were not even the right numbers for that motor and they were gaped at .040. New plugs are set at .030. I also checked coils and plug wires with oms meeter and the checked out good. Not sure where to go from here. I know lowering prop from a 23P Balistics is not the answer because the boat gets on plane very quick with little efort. I also checked carbs for WOT and they are all perfect. Help.
