I have replaced both filters in the high pressure fuel pump, water separator, plugs, o2 sensor, had all the injectors cleaned, all cylinders are at 225 psi and still cant get on a plane. the rpms will not go over 3000 at full throttle and after a short while of running we get a constant alarm and motor goes into a rough shake. at home after 45 min of running on the hose I get a beeping alarm, I have ordered both thermostats and o rings and will change. I am scratching my head on this one, hopefully someone can help.
