Hello Everyone!
My name is Allois and I run a surf, fish, dive camp in Pohnpei, Micronesia.
I have 4 Hondas 150 hp.
One of them with around 1.500 hours has been overheating at 4.000 rpm
It started to overheat at higher rpm and since then lower to 4.000 rpm.
I have swapped parts with other Hondas 150 as an elimination process.
I have swapped the lower units so pump and anything on the lower unit is not the problem.
I have swapped all sensors and thermostat.
I flushed it with discaler many times.
I feel the problem is with some obstruction in the cooling system and it looks like there is a bit less waters coming out of that pisser at a higher temp.
I have pushed water with a lot of pressure and air through the colling system and took as much of it as I could apart to make sure there was no obstruction.
Do you have any ideas of what could be the problem or where the obstruction could be at?
Thanks.
Thanks.
