R
rdc
Guest
" I have had a reoccurring pro
" I have had a reoccurring problem. In the middle of running my boat, the engine will suddenly cut out. When I try to re-start the engine it just cranks over and doesn't seem to even fire. After a while of cranking the motor, it will eventually fire up and at first run erratic at first and then run perfect. I have been fishing some days and nothing happen and other trips happen within the first two hours. I have changed the fuel filter and it didn't work. I have talked to my local boat mechanic and he seems to think it is electrical. I will eventually take the boat in to be fixed after I decide which arm and leg I can do with-out, but if you have any ideas please advise. "
