Results 1 to 2 of 2
  1. #1
    Default 1gm 10 takes forever to start
    hi all. ive just bought a little 22ft yacht with a 8hp yanmar 1gm 10. its no in the water yet as im trying to start it without having to run the battery flat each time .ive tried bleeding it and can only get fuel to the second point with the little finger pump thing but cant get it to the injector that way,so ive been turning over the engine to get it to the injector. the pump lever does'nt get any stiffer or feel like there is any pressure is this normal? i cant see any fuel leeks from joints. when its started it seems to run ok. any ideas what to try?
  2. #2
    Join Date
    May 2015
    Location
    Oregon
    Posts
    77
    Default Re: 1gm 10 takes forever to start
    Diesels need 3 things to start. Fuel, heat and compression. Are you getting fuel to the injector? Loosen the line running to the injector while cranking. Make sure the stop lever and linkage is in the run position. The engine needs enough compression to raise the temperature above the ignition point. As engines age, some compression slips past the rings. Usually glow plugs or block heaters solve this problem (more heat, less compression needed). Also, the engine needs to turn fast enough to build pressure before too much escapes past the rings. Use ether sparingly. It rapidly raises compression above normal. Too much will break rings. Then you need it every time. You should be able to start the engine with the hand crank. Don't burn up the impeller.
    If you need a manual you can download a pdf here: http://j30.us/files/yanmar-manual.pdf
Similar Threads
  1. Mercury 7.5 takes forever to get started
    By MilesAway1980 in forum Mercury Mariner Outboard Forum
    Last Post: 09-19-2012, 05:49 PM
  2. 2000 merc 15 hp 4 stroke takes forever to warm up
    By tkms002 in forum Mercury Mariner Outboard Forum
    Last Post: 06-28-2011, 07:11 PM
  3. My 175HP Envirudes Outboars take forever to get them start when they are cold
    By Jorge Oubina in forum Johnson Evinrude Outboard Archive
    Last Post: 12-17-2007, 04:44 PM
  4. DF250 takes 3 tries to start
    By hoffmaster in forum Suzuki Outboard Archive
    Last Post: 11-12-2007, 12:50 AM
  5. 1982 Johnson 75hp 3cyl takes forever to warm up
    By frankanderson in forum Johnson Evinrude Outboard Archive
    Last Post: 05-08-2004, 08:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
