OK, On our family emergency we passed through Shasta Lake City 1 mile from Shasta Dam. Lots of outboard boat shops in the area. We pulled in to one who specializes in old Johnson motors. He said they check the fuel pressure with a vacuum gauge, must be 3 to 5 inches of vacuum.But like ones on the forum he told me to go out on the lake warm the motor up then turn it on when it starts to run out of fuel pump the primer bulb.I did this it planed the boat ran full power stronger than ever, Then the bulb went completely flat like it was sucked dry and the motor died.But did start up first pull and run fine at slow speed.One would think there is nothing wrong with motor or carb overhaul.Or the new fuel pump.I doubt now even the old one was bad. That leaves only the fuel bulb , and the fuel tank which is a plastic after market tank.I see no way to pull the pickup tube out or check it.I will replace the bulb. I have done lots of mech.work but none on boat motors. WHAT am I missing here? thanks.
