Results 1 to 4 of 4
    Default foriegn objects in manifold
    1958 Hercules engine with valve problem. I couldn't get either valve to work on #2 cylinder. Finally removed the manifold and have pulled 31 acorns from the exhaust holes in the manifold and exhaust valve holes in the block. There are more that I can see down the exhaust pipe. Boat has been stored in the previous owners barn for 30+ years. I noticed a pin across the exhaust pipe when it was detached from the manifold. Should there be a "butterfly" check valve there to prevent stuff from entering the exhaust manifold?
ID:	13173   Click image for larger version.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,272
    Default Re: foriegn objects in manifold
    Ayuh,.... I believe there should be a rubber coated shutter there, Yes,....
    Any idea where to get one of those shutters?
    Dec 2006
    5,272
    Nope,.... Not a clue for such an ole obsolete antique motor,....
    Worst comes to worse, Fab one up,....
    I built my own thru-pipes, 'n shutters outa some ssteel I had layin' 'round,....
    Then bolted a piece of heavy rubber to the shutter, after a day of clickity clackin' for 18 hours fishin'/ trollin',....
    That was over 10 years ago,...
  1. Replies: 1
    Last Post: 07-29-2013, 11:18 AM
  2. OMC manifold ID
    By haminator in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-19-2011, 11:42 PM
  3. Strbd exhaust manifold hotport exht manifold coolwhy
    By dandidon in forum Mercruiser Sterndrive Archive
    Last Post: 06-30-2009, 11:45 PM
  4. Wet or Dry Manifold
    By paston1 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-23-2008, 10:23 AM
  5. R30 Manifold
    By yannick le guennec in forum Renault
    Last Post: 11-20-2005, 10:28 AM
