jasoncalleja
Hi all today i inspected the thermostats on cylinder head and engine block. what i did is this i started the engine in a water tank 200lts and left it idle for 15 min then i removed the thermostats the one on the head was open but the one on the block was still closed i have restart it again and left it for another 15 min and did the inspection again and the one on the block was still closed. i have restarted again and left it for another 15 min for a total of 45 min water started to heat up but again it did not open then i swap the thermostats the one on the head (50[SUP]o[/SUP]C) with the one on the block (60[SUP]o[/SUP]C)and started the engine for 5 min removed the thermostats and the (50[SUP]o[/SUP]C) one opened on the block but the (60[SUP]o[/SUP]C) that was on the head did not opened
then i put the thermostats in a pot with water and heated up the water and the thermostats open first the (50[SUP]o[/SUP]C) then the (60[SUP]o[/SUP]C) which means that they work. what i would like to know what time should it take to warm up the engine to open the thermostat and if they where installed properly the (50[SUP]o[/SUP]C) on the cylinder head and the (60[SUP]o[/SUP]C) on the engine block. i need to know the time to open the thermostats to know how much i have to operate it to rinse it from salt water. sorry to write so long but to try to explain what i done and need to know. thanks
