Hello everyone.
I changed the seals out in the gearcase and put it back together.
I was very careful putting the gears back together and thought it was
correct.When i pushed the shift rod it moved up and down as it did before I took it apart.
When I put it back into the upper unit I had to put the shift lever in reverse , I think , to get the shift rod back into the shift rod connector.
I just took it out on the water and it shifts into reverse and neutral just fine but no forward.
Does any one have any suggestions before I take the gearcase back apart.
Thanks for any help.
