willow
Hey it's a weekend...please indulge me....... Here is my question ..after an explanation.
I have a drain hole with a screw-in-plug in the lowest part of my transom.The plug is installed from outside and is removed for winter storage. The problem is that the way the boat was designed, the plug had to be installed almost 4 inches above the lowest part of the inner transom. The result is that each Spring I end up with water in the stern, "almost" up to the oil pans..350s with V Drives.
Now would it be acceptable to install a drain hole near the stern but come up through the bottom of the hull ??? Once again the plug would be in (obviously) when the boat is in the water but out for winter storage and I am guessing it would be a brass plug, flush mounted with the hull when inserted.
You are wondering how the water gets in???? Live up north, boat not covered, left outside all winter. The entrance to the engine room is a lift-up hatch about 5 feet wide and 4 feet long with a drain rim all the way around. The problem is that with snow, and then a melt and then a freeze, the hatch can work up an inch or so and water invariably gets in...no damage as the engines etc. are draped in tarps but the 8 gallons of water in there every Spring is really annoying.
So back to the question....has anyone ever had a drain hole installed from the bottom of the hull upward???
