Ok
do you have a 12 volt test light?
If not they are about $10.00
Reproduce the problem and then you need to probe for voltage and using a test light is the quickest way to do it. the intensity of the light tells you right away you have good power.
The wiring of these systems is fairly easy.
With no key on, you should have 12 volts (battery voltage) on the RED 10 gage wire going to the dash thru the large connector. this should also be on the key switch on one terminal. Some have a fuse link before the key switch so if you have that look for the fuse and check it for corrosion or bad connections. Typically 20 amp.
When the key is turned to the on position only, the power is put to one of the other two terminals. Purple should be the color if not you have an older wire configuration. That purple goes all the way back thru the big connector, then goes to the choke, the Alternator and connects to the resistance wire buried in the on engine wire harness which eventually connects to the coil +. That is it for the on circuit.
The other terminal on the key switch is CRANK. That should be a yellow with red wire. when the key is in the crank position power now goes thru the neutral safety switch in the shift control box and then thru the big connector and then to the slave solenoid and then to the starter solenoid.
The starter solenoid has two small terminals on it that are used (point ignition only in this case). One is the power to the solenoid to energize it and the other is the wire (power) to the coil when cranking. Newer electronic ignition boats this is done at the key switch.
Ok now we understand where the power comes from and where it goes.
The rest of the wires going thru the big connector are for tachometer, temp, oil pressure, etc. (input/output) nothing to do with power or ignition. With the exception of the tachometer lead which can influence the ignition system if the tach is bad and internally shorted. Then simply removing the tach wire from the NEG side of the coil will determine this. This would be bad running and or miss firing or no start but it would crank.
Now there is the Alternator wiring, There are 4 connections,
Ground BLACK
Output to battery thru starter main lug. Typically ORANGE
excitation, Purple this is mentioned earlier
voltage, red with purple comes also from the Starter big lug and goes thru a larger 50 amp breaker.
That is about it.
Now if you do what I recommended in my earlier post and make a hot jump/start rig you can disconnect the big connector and start the engine and if it does not die then you know the issue is in the dash or harness leading to the dash from the connector.
Until you determine this it will be difficult to determine where to look for your issue. Isolating the motor wiring from the dash wiring is standard trouble shooting.
Once we know if the problem is either in the dash wiring or the motor wiring then we can go from there.
Attached is a diagram for the hot start rig
