Click for Perkins manuals!
Results 1 to 2 of 2
  1. #1
    Default Perkins Sabre M135 - White smoke and Enginge shut off
    Have a problem with our Perkins Sabre M135.
    At the beginning of March:
    - The engine was run at 1400 RPM
    - White smoke coming from the exhaust,
    - RPM went alone HIGHER,
    - engine did not want to shut off, even with Manual Shut off.
    - turned off alone,
    - Engine don't start
    - boat had to be towed
    Mechanics found no cause.
    Yesterday April 13
    - White smoke from exhaust,
    - assumed engine itself,
    - Engine don't start again,
    - left and right side from engine oil slightly
    Mechanic doing the following:
    - Opened injectors (all 6) no diesel coming)
    - fuelfilter check (Diesel ok)
    - try to start (no start)
    - check Intake, (open venting screw,Oel came from the intake)
    - Start test (Engine Starts)
    (He says injetors ok, Head gasket ok)
    But what may be the real cause? Does anyone have any help?
    Thank you
    Walter
  2. #2
    Join Date
    May 2015
    Location
    Oregon
    Posts
    81
    Default Re: Perkins Sabre M135 - White smoke and Enginge shut off
    Check your stop solenoid. If your injector pump has a stop lever, make sure it's able to move to the run position. Check any stop circuits or linkage.
    When injector pump has fuel (bleed to check) and no fuel at the injector tubes, indicates stop condition at pump. Stop solenoid (or lever) energized in run position moves fuel cam. White smoke could mean lean burn, stop not working properly.
Similar Threads
  1. Perkins Sabre M135 Oil cooler!!!!!!!!!!!!!
    By captmorgan in forum Perkins
    Last Post: 07-16-2015, 07:14 AM
  2. Perkins M135 over charging
    Last Post: 11-24-2012, 02:01 PM
  3. Replies: 8
    Last Post: 04-11-2011, 09:05 PM
  4. Replies: 0
    Last Post: 01-04-2011, 07:10 AM
  5. Perkins Sabre M300Ti
    By glljansen in forum Perkins
    Last Post: 05-06-2006, 02:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
