Results 1 to 2 of 2
    Default 2005 240 Sundeck, replaced electric fuel valve, still won't stay running
    5.0 Bravo 3R, the boat has an electric fuel valve which has a line from the fuel tank to the cool fuel box with the fuel pump. The valve became too hot to touch and the boat would not start. I just replaced the valve. My understanding is this valve shuts off the fuel in case of a fire and has to do with the halon system.
    Note: the original valve had a psi of 10 but the new replacement PER the SeaRay dealer is now a different part number and has a psi of 2.
    I have primed the lines but the fuel pressure does not hold and the boat will not stay running. Any suggestions of what could be the issue. The electric fuel valve is now warm when I try to start it, whereas I replaced it because it was too hot to touch.
    The photo attached is the valve that was replaced.
    Is there a fuse that could be a problem? How do I narrow down the problem or a solution?Click image for larger version.
Name:	electric fuel valve.jpg
    Dec 2006
    Chaumont Bay, N.y., USA
    5,886
    Default Re: 2005 240 Sundeck, replaced electric fuel valve, still won't stay running
    Ayuh,..... By-pass that valve, 'n see if it'll run,.....
  1. 45hp Mariner,,replaced rectifier and now electric choke wont work
    By recantrell in forum Mercury Mariner Outboard Forum
    Last Post: 12-01-2012, 10:49 AM
  2. 1990 9.9 electric E10RELESC will not stay running
    By buldogbil in forum Johnson Evinrude Outboard Forum
    Last Post: 09-17-2012, 09:58 AM
  3. 2005 Evinrude Johnson 75 ETEC wont stay running
    By marineman43 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2009, 08:48 PM
  4. 57 vs 50 for sundeck
    By watsie50 in forum Marine Power Engine Forum
    Last Post: 05-16-2008, 08:22 PM
  5. 1986 Evinrude 99 cant get enough fuel to stay running
    By gdubya in forum Johnson Evinrude Outboard Archive
    Last Post: 10-16-2007, 01:46 AM
