I have a pre 92 NS70A Nissan Outboard. It is on a 20ft pontoon and for some reason it will not open up under a load. I can get it to open up in neutral or in gear without a load but once I put it in the water it sounds like it is bogging down. Compression is 150 psi top and bottom both plugs are firing and I removed both carbs tore them down completely and dipped them both so they are spotless. The Woodruff Key sheered on the fly wheel and I replaced that. How do I link and synch that model engine? I can not find anything online on this model. The repair guy I use just wants to start changing parts until he finds the issue. That can be pricey. Could some one possibly help me Out?
