Click forPleasurecraft Marine parts and manuals!
Results 1 to 8 of 8
  1. #1
    Default 2000 PCM alternator swap RA097006 for SIERRA PART #18-5957
    I have a 2000 PCM 5.7 and I am changing the alternator. I ordered the replacement for RA097006 and received the SIERRA PART #18-5957 which is the direct replacement. The new alterenator came in with the 2 wires red and black out of plug. My boat has the yellow always hot a black and a green wire. I looked it up it said green for ground,so i hooked yellow to red and black to black. It will not turn over and when I hold the key I pop the ignition breaker. Any ideas?
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,097
    Default Re: 2000 PCM alternator swap RA097006 for SIERRA PART #18-5957
    tru disconnecting the black and green small wires The yellow (always hot) goes to the output post ,If you have a large
    black, it goes to the ground post. The other 2 small wires are "sense" reads battery voltage , and excite" ,has power with the key "on"
  3. #3
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,097
    first or second pic?
  4. #4
    Quote Originally Posted by Bt Doctur View Post
    Second pic. I hooked the orange to the red, green to black and boat black to ground. It started fine but is only showing 12volt on the volt gauge.
  5. #5
    The original alternator was the first picture
  6. #6
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,097
  7. #7
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,097
    the red pig tail must go to the always hot wire at the output post, the black goes to switched 12 v like from the + side of the coil. try that test the green wir for 12v with the key on" if yes .put that to the black pig tail wire from the new alt.
  8. #8
    Thank you so much for your time. I have been out of town and plan to get on this Saturday. Again thank you.
Similar Threads
  1. Alternator part number for 6-71TI
    By Russ Appleton in forum Detroit Diesel
    Last Post: 10-24-2013, 03:50 PM
  2. 318 Alternator Swap
    By ajitsayan in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-04-2011, 08:47 PM
  3. Swap Alfa 1 for Sierra
    By aussie_trev in forum Mercruiser Sterndrive Archive
    Last Post: 11-28-2007, 08:29 AM
  4. 1Way to 3Wire Alternator Swap
    By mike77cj in forum Volvo Penta Gas Archive
    Last Post: 06-28-2007, 05:04 PM
  5. Swap Delco alternator for Paris Rhone
    By Rob J in forum Volvo Penta Gas Archive
    Last Post: 05-30-2007, 01:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
