Results 1 to 4 of 4
  1. #1
    Default Tie Down wieght ratings
    Does any one have a rule of thumb for transom tie down weight capacity vs boat weight? I have a bunk trailer with a 21 ft Sea Ray that weights about 3500# with a full tank of gas - how much should the rating of the transom tie downs be?
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,894
    Default Re: Tie Down wieght ratings
    Ayuh,.... Gravity does most of the work,...
    The straps are just to control bounce,....
    Any of the usual tie-downs will work,....
  3. #3
    That's what I thought. Bought news one that look plenty strong yet they say only rated for 400 lbs. CYA...
  4. #4
    Join Date
    Mar 2007
    Location
    Miami Lakes, Fl, USA
    Posts
    113
    400 lbs rating they most be one of the real thin ones, if you do any long distance trailering and the straps are to narrow you may attract some unwanted attention from leos.
Similar Threads
  1. Help with HP Ratings
    By shawn in forum Johnson Evinrude Outboard Forum
    Last Post: 06-07-2010, 09:35 PM
  2. 140 HP Chrysler outboard wieght
    By gambler1960 in forum Chrysler Force Outboard Archive
    Last Post: 11-01-2007, 12:37 PM
  3. 43L Horsepower Ratings
    By rod_stewart in forum Mercruiser Sterndrive Archive
    Last Post: 10-11-2006, 10:46 PM
  4. 43 L HP ratings
    By s in forum Mercruiser Sterndrive Archive
    Last Post: 05-04-2006, 08:58 PM
  5. Horsepower ratings
    By Kirk Spradling in forum Johnson Evinrude Outboard Archive
    Last Post: 08-13-2003, 02:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
