Results 1 to 2 of 2
    Default 91 johnson 120 v4. vro / standard fuel pump swap.
    anyone out there know of a standard fuel filter that can replace the broken vro pump om my 91 j120tlei? I feel like ive gone thru all the procedures of carbs and other motor issues but feel strongly the vro is creating to much air or built up sludge or som,ething into the engine. who knows its a 25 year old pump that's been capped off. the fuel system was completely redone except for the pricey pump. please someone tell me I can find a 40$ fuel pump that I can make work!
    Sep 2010
    ontario
    14,156
    Default Re: 91 johnson 120 v4. vro / standard fuel pump swap.
    Myself I would go to the parts shelf and install a pump off a 1966 model 100 hp.---------No money spent.------Your luck may vary
  1. Replacing VRO fuel pump on Evinrude 130 HP with standard fuel pump
    By Topkick8 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-03-2015, 10:07 PM
  2. VRO Replacement W/T Standard Fuel Pump?
    By jprevat in forum Johnson Evinrude Outboard Forum
    Last Post: 04-22-2014, 10:58 AM
  3. vfo swap to electric fuel pump 60 hp johnson
    By mbrizzly in forum Johnson Evinrude Outboard Forum
    Last Post: 07-06-2012, 11:00 AM
  4. VRO to fuel pump swap
    By bwaybrown in forum Johnson Evinrude Outboard Archive
    Last Post: 04-29-2009, 03:45 AM
  5. Replies: 1
    Last Post: 05-18-2004, 11:01 PM
