aquasport f115
Yamaha f115 randomly dies when above idle.It doesn't do it when rectifier is unplugged. replaced rectifier and stator. cleaned connections and new batt cables. engine is charging when rectifier is plugged up. The rec also gets pretty hot. also when it dies or sometimes surges the tach go completely off like no power. thanks in advance if i think of any other stuff its doing or not doing will post. problem started when i had alot of corrosion inside my batt cable to care of all that rec was burnt replaced still had problem replaced stator . It worked for one trip then problem again. Sorry for grammar not publishing a book . thanks !
