MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default 8hp Mercury faster prop
    Hey guys I got a 8hp 2 cylinder 2 stroke Mercury from the 80's. Can't remember the exact year. Anyways I run it on my 8ft sea flea and it has no trouble pushing me along the motor doesn't bog at all. It runs about 22mph. I was wondering if there is a different prop I could get for it so I could get it moving faster. If I can does anyone know what I would need to gain more speed? Thanks for any input!
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default Re: 8hp Mercury faster prop
    Nope - at least not any speed you would notice.
    If you have the factory OEM prop it will be a 9 pitch.
    Michigan Wheel and Solas makes a 10 pitch that will fit but going to the higher pitch also drops your max rpms plus the prop bites harder and "slips" more (slip is present in all props and not something you can mitigate).
    I have tested 8P, 9P, 10P (3 blade) plus a 10P 4 blade on a 9.9 Merc (1986 model) and under the same conditions (swapped all the props at the lake, so all testing was within the same hour or so - as scientific as you can get in "real life") and the results (gps - only myself on my 14 foot aluminum) were "all within 1 mph" - which is almost a rounding error.
    If you want more speed, and can tell you now 22mph from an 8 horse is awesome, strap on a 15 or 20 horse (even going to a 9.9 might only give you 2 more mph).
    There is essentially "nothing" you can do to that 8 horse to gain "speed you will notice", unless your only goal is to see 22.2mph on the gps instead of 22.0mph.
    You can replace the exhaust plate and tube (one unit), retro-fit a new water tube (because the old ones will not fit the new plates and you have to drill out the pass through hole in the exhaust housing for the new tube to fit) and then replace the carb with one from a 9.9 and you will improve your top end speed by about 7% (1.5 mph on flat water with no wind). And yes, I have done the conversion for more than one motor - some guys don't mind spending 300'ish bucks - at least the last time I source parts - to be "faster".
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    I have a Mercury 6hp twin merc 60 motor. The motor runs but when I put it in gear the boat does not move . I removed the propeller but I can't see anything wrong. Any suggestions?
  4. #4
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,945
    possible spun hub inside of prop.With engine shut off shift and listen to l/u for click in gearbox.
Similar Threads
  1. new prop? Seems it should go faster merc90
    By THE LONE SHARK in forum Propeller Selection and Replacement
    Last Post: 06-06-2013, 09:22 AM
  2. 5hp Mercury will she go faster
    By david_sims in forum Mercury Mariner Outboard Archive
    Last Post: 04-20-2008, 08:33 PM
  3. FASTER FASTER
    By cobb in forum Mercury Mariner Outboard Archive
    Last Post: 01-29-2008, 10:05 AM
  4. 1984 4cyl mercury 50 got loudstarted idling faster
    By john r. allen in forum Mercury Mariner Outboard Archive
    Last Post: 09-11-2007, 11:11 AM
  5. Going Faster
    By Richard Whitling in forum Outboard motors archive 2000-2004
    Last Post: 09-16-2002, 10:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
