Results 1 to 7 of 7
Thread: siezed engine
    Default siezed engine
    hello I have a seized 350 it was said its seized from sitting to long I've tried marvel oil, PB Buster, and a 1/2" braker bar with do luck. I was told buy an old timmer to try pepsi-cola. does anyone have a idea that may work, I really don't want to snap the damper bolt off. there was no water on the dip stick so I am guessing its frozen rings. but that is just a guess at this time.
    Thanks Bob
    Default Re: siezed engine
    MOD. NO. MP350ANS
    SER. NO. AN89033612S
    MARINE POWER INC.
    Thanks Bob
    Sep 2010
    Jersey Shore
    4,826
    If it's frozen its done.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
    Mar 2009
    Portland, Oregon,
    9,714
    DO NOT use the front crankshaft balancer bolt for this!
    Try a strap wrench.
    Try making a tool that will fit into the three spokes of the balancer.
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Oct 2012
    sacramento, ca.
    306
    myself.....i would pull both heads off and start there. replacing gaskets are cheap . even if you do free the engine, i would want to look at the cylinder walls.
    *** In comparing the virtues of various calibers, using hollow point ammo: it is absolutely undeniable that, while a 9 mm or .40 S&W may or may not expand, a .45 will never shrink. ***
  6. #6
    My next step is to pull the heads, but I am looking to also make a jig to fit the bolt pattern on the damper and turn the crank shaft that way
  7. #7
    Dec 2005
    130
    I know this is an old thread, and I hope you have had success with the motor by now. Part of the problem with the heads still on, might be the fact the valve stems are rusted too. In addition, the lifters may be stuck, all keeping the motor from spinning. Removing heads and intake will expose all of this for direct application of penetrating fluids. :-)
  1. SIEZED MOTOR
    By yachtie in forum Yamaha Outboard Forum
    Last Post: 11-25-2009, 04:52 AM
  2. Siezed Perkins HT 6354 Diesel Marine Engine
    By kellymick in forum Perkins
    Last Post: 08-18-2009, 04:46 AM
  3. Overheated engine amp siezed
    By roger766 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2008, 01:41 PM
  4. 30 ltr GM engine siezed help
    By buck in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 04-28-2006, 11:32 PM
  5. 25 hp siezed up
    By epflynn in forum Archive 2003-2009
    Last Post: 05-07-2003, 11:59 PM
