Results 1 to 5 of 5
Thread: Engine rpm
  1. #1
    Angry Engine rpm
    introduction
    I purchased two motors furnished VOLVO PENTA AD41-P 220 HP
    The engines were installed 35-foot boat propulsion VOLVO PENTA with DO PROP (A5 PROPELOR SIZ)
    I installed one of the motors with transmission in size 23 foot boat (including engine weight 1500 kg
    Boat Standard
    Engine system repairs
    1 injection pump overhaul
    2 Renovation injectors
    3 turbo overhaul
    4 new diesel filter
    The problem
    When I step into reverse engine responds Excellent reaches 4200 rpm
    But when I step Front gear motor can not to pass above 1500 rpm
    In addition warms up (I checked the cable from SIFT is fully accessible)
    To refine the explanation even when I bring up the TRIM
    My question is whether someone has encountered a problem or something identical
    I thank everyone who can help me find a solution to the problem
    I live in Israel and in Volvo's service is very bad no one to talk
    Volvo does not even Mechanic 1
    Too bad I chose Volvo
    Sincerely ASI Elijah
    Mobile + 972-52-444-4444
    [email protected]
ID:	13024Click image for larger version.
ID:	13021Click image for larger version.
ID:	13022Click image for larger version.
  2. #2
    Default Re: Engine rpm
    introduction
    Boat Standard
    3 turbo overhaul
    4 new diesel filter
    The problem
    [email protected]
  3. #3
    Volvo penta
  4. #4
    Volvo penta problem
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    Start a new thread in the volvopenta diesel forum. Does the throttle body fully open up in forward gear?
Similar Threads
  1. Power assist steering is smooth as butter with engine running. Hard with engine off.
    By Bluecollerboater in forum Volvo Penta Gas Engine Forum
    Last Post: 06-17-2015, 10:31 AM
  2. No power to engine: Johnson 90 HP VRO boat engine (model j90TLAEM) - photos included
    By muskiediver in forum Johnson Evinrude Outboard Forum
    Last Post: 07-14-2013, 08:04 PM
  3. '85 75HP Merc engine Tilt/Trim just clicks - engine stuck in the DOWN position
    By JEVaught in forum Mercury Mariner Outboard Forum
    Last Post: 07-07-2013, 04:21 PM
  4. Small amount of water entered engine Compartment and now engine wont start
    By artaudio in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-29-2008, 09:54 AM
  5. Replies: 3
    Last Post: 05-27-2003, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
