I have a 02 yamaha 2 stroke 150, I put a new water pump in it a year ago and ran it almost every weekend. It sit the last 3 months so I hooked it up to miffs to make sure no problems. It melted the water pump housing in less than a minute running. I flushed the motor in every way possible, no blockadge.I put new everything on for water pump, started again. And melted it again in less than a minute. I can attach hose to the flush hose on side of motor and run the motor with lower unit off, doesn't over heat pissing great. Put lower unit on, not pissing. I have called 8 different techs and showed 2, no one knows why. Any ideas on what to try now? Water pump is on right, and didn't help when put in a run tub
