1986 Evinrude 40 HP - E40ELCD - Power Trim Operating SLOW
Thanks Boobie... Will do.. Also, I'm wondering if I should change out the hydraulic oil? I also see a hole @ where #44 is on the drawing that says 'oil' ?? Is this gearcase oil?
No. It's where you put oil in for the T/T. Try putting some T/T fluid in there and see what happens and get a plug for it.
Update: I checked all wiring connections & found the ok. I figured out hat I thought was a 'hole' was an allen wrench plug. I remove both the top & bottom plugs & it was completely DRY. Being in a rural area, I didn't have a source for T/T fluid so I filled with ATF fluid and BINGO,problem solved. I'm thinking if this may supposed to have gear oil? I haven't been able to find much documentation on this particular unit. Whatever, no more than T/T is used having ATF is way better than being DRY!
THANKS, Boobie & everyone else
ps forgive typos - this forum does not respond wll to m typing.
