Results 1 to 2 of 2
  1. #1
    Default Checking Trim & Tilt oil 2005 Verdo
    How do you check trim and tilt oil on 2005 Verdos 250 HP?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,913
    Default Re: Checking Trim & Tilt oil 2005 Verdo
    Checking Power Trim Fluid
    1. Tilt outboard to the full up position.
    2. Rotate the tilt support bracket down.
    3. Lower outboard until tilt support bracket rests on pedestal.
    4. Remove the power trim fill cap. The fill cap only requires 1/4 turn to remove. You will see the cap on top of the rim assembly.
    5. The fluid level should be approximately 25 mm (1 in.) from the top of the fill neck. Add Quicksilver or Mercury Precision Lubricants Power Trim and Steering Fluid. If not available, use automotive automatic transmission fluid (ATF).
    6. Install the power trim fill cap. Tighten fill cap 1/4 turn. Cap will snap in place. Do not tighten beyond this point
ID:	12945 Open this picture in a new tab by right clicking on it.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
Similar Threads
  1. trim tilt doesnt trim tilt on my 1987 70 hp johnson outboard
    By OBG in forum Johnson Evinrude Outboard Forum
    Last Post: 10-15-2016, 02:05 AM
  2. Starter and Trim/Tilt - 2005 90 HP 2 cycle
    By Lerie in forum Mercury Mariner Outboard Forum
    Last Post: 02-08-2015, 11:23 AM
  3. HELP - Yamaha 40hp 2 stroke trim and tilt 2005 model
    By Garryb in forum Yamaha Outboard Forum
    Last Post: 10-23-2011, 06:43 AM
  4. checking oil power trim
    By myunclepapa in forum Johnson Evinrude Outboard Forum
    Last Post: 10-12-2011, 08:26 PM
  5. 2005 suzuki 140df I need know how to bleed and refill power trim and tilt
    By JasonBishop in forum Suzuki Outboard Archive
    Last Post: 07-21-2008, 11:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
