Click for Perkins manuals!
Results 1 to 3 of 3
    Default Diesel fuel problem
    Help, can anyone tell me why I have engine oil getting into the fuel?? I thought I had a dirty diesel tank but have now installed a new stainless steel tank, and after cleaning all lines and new fuel filter a few hours later and my fuel is black again, I know it is engine oil ,how can Ifix please?
    May 2015
    Oregon
    73
    Default Re: Diesel fuel problem
    The usual fuel/oil contamination is caused by the front seal in the injector pump failing. But I've only seen fuel getting into the oil, not oil into the fuel. The pressures inside the pump is usually greater than the pressures in the crankcase/gear housings. You don't say what engine, I assume a Perkins. I can't think of any other place where engine oil and fuel are close together. Are you losing oil?
    Thanks for that information on my diesel fuel problem and yes it is a perkins 4107,I will get a seal kit for it,and hopefully my problem will be solved thanks again
  1. old diesel fuel still ok?
    By wenders in forum Ford Lehman
    Last Post: 05-03-2016, 01:18 AM
  2. Diesel fuel injector
    By glennnichols in forum Volvo Penta Diesel
    Last Post: 01-27-2009, 10:23 AM
  3. Diesel fuel in oil
    By Roy Ericson in forum Perkins
    Last Post: 11-15-2008, 06:56 PM
  4. Diesel Fuel In Bilge
    By adubuisson in forum Miscellaneous marine engine topics
    Last Post: 11-11-2008, 02:18 PM
  5. Old Diesel Fuel
    By thewordmerchant in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-22-2003, 11:41 AM
