I have a 1979 Glastron Carlson CVX16SS with an OMC 140 HP 3.0 want to change over to Electronic Ignition Distributor.
Would like to hear your experiences with your change over. And if this went trouble free or challenges that you came across. Also what part number of the kit you got if for OMC 140 3.0
thank you
Your thread title and your first sentence suggest a "new ignition system", yet you go on to mention a "Kit".
The kit is often the Pertronix unit.
Here's the down side of the Pertronix kit:
The old contact point system is replaced with a sensor unit and a magnet embedded plastic triggering wheel.
The kit uses Hall Effect triggering via a very small diameter triggering wheel.
These triggering wheels have been known to offer a discrepancy of up to several degrees error.
The kit does ZERO to correct any existing components that may be worn out.......... shaft bushings, advancing system, etc.
If you are OK with that.... then the Pertronix may be just fine for you.
If you are NOT OK with that, I'd suggest one of two options:
a..... Have your old system tested by a shop who owns a Sun, King or Allen machine. Once corrected, install the Pertronix kit and test again.
b..... Replace with a completely new system.
