Results 1 to 2 of 2
  1. #1
    Default basic question Zephyr Saildrive issue
    As a newcomer to marine engines, I think this is probably a basic question for many of you. I have a Zephyr OMC Saildrive gas engine. When starting, I have 2 symptoms: 1. It is very hard to start. It cranks, but takes quite a few tries to catch. 2. When I do get it to start, the engine RPM is very high, in the 3-4,000 RPM range. Usually, it will eventually go to normal idle and I can get on my way. But even then, I've had I shut off on me and it's very difficult to restart. Does this sound like a vacuum leak?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,259
    Default Re: basic question Zephyr Saildrive issue
    Step # 1 is to check for spark.----------Spark must jump a gap of 3/8" on both leads.--------Then you do a compression test.--------How old is the fuel and has the boat sat for a long time ?
Similar Threads
  1. OMC Zephyr 15HP 2 stroke cooling question
    By 27floater in forum OMC Sterndrive and Inboard Forum
    Last Post: 04-14-2014, 02:02 PM
  2. OMC Zephyr Saildrive Mechanic
    By mailstop8689 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-27-2009, 01:09 PM
  3. FuelOil mix ratio for OMC Zephyr Saildrive
    By J.W. Snowgen in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-07-2007, 09:25 PM
  4. EVINRUDE ZEPHYR #4429
    By bradhayd in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2006, 08:01 PM
  5. OMC SAILDRIVE 15HP ZEPHYR
    By DAVE BYRNE in forum Archive 2002-2006
    Last Post: 11-16-2001, 09:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
