Click forPleasurecraft Marine parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default which timing do i set 351w at 6 degrees btc at 600 rpm or 10 degrees btc at 600 rpm
    Hi All,
    I looked up under 2 different PCM owners manuals--- one says for ford 351w set the timing at 6 degrees btc at 600 rpm the other PCM manual says timing at 10 degrees at 600 rpm. I have a new rebuilt 351w and I have to break in the engine with no idle time- start the engine up and immediately run to 1800 to 2400 rpms for 20 to 30 minutes to break in the flat tappet hydrolic cam and to seat the piston rings so I don't want engine detonation. We will be running the boat with engine out of the water = loud exhaust so I am not sure I could even hear the engine knocking or pinging noise. your thoughts please
    thanks,
    tmcboat
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,697
    Default Re: which timing do i set 351w at 6 degrees btc at 600 rpm or 10 degrees btc at 600 rpm
    Ooops.... double post.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,697
    Pay little attention to BASE advance, and focus more on the Progressive and Total Advance and the RPM at which these occur.
    I also posted to your thread in the Volvo Penta forum.
    http://www.marineengine.com/boat-for...tdc-at-600-rpm
    Portland, Oregon
  4. #4
    Hi Rick,
    Thanks for all your help --- do you have a PCM ford sb-351w advance curve and total advance chart or a site where I can google it?
    thanks,
    tmcboat
Similar Threads
  1. Replies: 21
    Last Post: 02-26-2016, 08:03 AM
  2. Merc 170 shuts down at 180 degrees
    By rrdbllc in forum Mercruiser Sterndrive Forum
    Last Post: 05-13-2011, 10:14 PM
  3. SP 230 overheating 195 200 degrees
    By migmatic in forum Volvo Penta Gas Engine Forum
    Last Post: 10-22-2009, 12:04 AM
  4. No shifting until 120 degrees
    By juniinc in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-08-2009, 11:40 AM
  5. One engine 10 degrees hotter
    By rmm in forum Crusader Marine Engine Forum
    Last Post: 08-05-2009, 05:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
