I have an issue where when I shift from reverse into neutral (NFS8A2) reverse stays engaged for several seconds before finally giving way to neutral. Its never caused a problem because I anticipate it, but in close quarters it gets a little nerve wracking wondering how long it will stick this time. I suspect that I caused this problem a couple years ago when replacing the lower pump case (due to some corrosion). Any ideas on what I may have done during a lower pump case replacement to cause this and how to test to confirm your theory and remedy it would be appreciated. Taking the lower pump case off could have jacked up either the drive shaft position or the cam rod position a small amount. But I am going in there soon to service the water pump so wanted to try and repair the error I made last time since I will have it part way disassembled.
Any advice on do's or don'ts of removing the lower pump case to try and figure out where the alignment of things went wrong would also be appreciated. I have read some comments on other threads about not removing the cam rod bushing, but I am getting some oil leakage around the cam rod at the bushing so was considering replacing the o-rings in there which would require removing the bushing.
