Results 1 to 4 of 4
Thread: Carb help
    Default Carb help
    I am trying to get a 1938 Johnson 1.1 hp motor to run. Good compression, clean tank, good fire. It will run briefly then dies. I think it is starved for gas. Have carb apart and cleaned. Re-coated cork float. My question is on the needle valve. How far should you have it opened from a seated position? Looks as if someone has had it apart before.
    Dec 2015
    maplevalley WA
    3,884
    Default Re: Carb help
    Does the needle have a nice smooth taper? Start wit 1 1/2 turns out and adjust it from there once the engine is fully warmed up. Turn it 1/8 turn at a time and wait about five seconds between adjustments. Turn it in until the engine coughs and then back out 1/4-1/2 turn. Best to run it rich to protect the motor
    Sounds good, I will try it. The needle is in good shape.
    Took carb all apart again and cleaned good. Back together but still just runs for just a few seconds and dies. I have tried moving needle to several different positions up to the point that spark plug comes out wet. Still just fires briefly then dies. Any suggestions?
  1. Looking for carb set for 125hp 1985 force plus carb question
    By Longislandboater in forum Chrysler Force Outboard Forum
    Last Post: 07-20-2014, 08:43 AM
  2. solex44pa1 carb need ball valve or new carb any ideas? thanks
    By mr moon in forum Volvo Penta Gas Engine Forum
    Last Post: 07-30-2012, 05:25 PM
  3. Replies: 8
    Last Post: 06-13-2011, 08:02 AM
  4. Mariner 40hp Twin Carb 1985 VS Mariner 40hp single carb 1998
    By Commando C2 in forum Mercury Mariner Outboard Forum
    Last Post: 05-10-2011, 10:43 PM
  5. Carb Tuning 1993 185 OMC Cobra Holley Carb
    By jmcmusicman in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-13-2010, 08:59 AM
